Página 2 de 4
Re: A Better Routeplanner (ABRP)
Enviado: 17 set 2018, 15:33
por migle
Perguntamos (eu posso perguntar). Escolheste http ou https? É http.
Enviado: 17 set 2018, 16:41
por migle
Eu vou meter isto aqui no forum, porque pode haver mais quem queira ajudar, mas talvez seja mais rápido continuarmos por email.
Temos dados, mas precisamos de ter a velocidade do veículo, a potência instantânea ou tensão e corrente e a temperatura ambiente. Os dados que temos são assim:
{"Long": "-9.14111", "BatTemp": "28.5", "pass": "", "Elv": "91.08622888837593", "SOC": "72.58240000000001", "SOH": "96.14", "Amb": "86.0", "ChrgPwr": "0", "Wpr": "9", "Lat": "38.73981", "RPM": "-23", "PwrSw": "1", "PlugState": "0", "Gids": "265", "Tunits": "C", "AHr": "76.4122", "user": "email@email.email", "DevBat": "65", "ChrgMode": "0", "Seq": "49", "VIN": "SJNFA... ", "Odo": "15382", "Trip": "23"}
Perhaps he can help me out with what the parameters mean. Here's my guesses:
Long/Lat/Elv - GPS location
SOC / SOH - State of charge and state of health of the battery
Amb - Ambient Temp
ChrgPowr - ?? Possibly input power, possibly input power level?
Wpr = ???
RPM = RPM of the motor?
PwrSw = ?Car on off state?
PlugState = 1 when plugged in?
Gids = ???
Tunits = temp units? Why s ambient temp 86? seems like F
AHr = Battery capacity in Ahr
DevBat = ??
ChrgMode = ??
Seq = ??
VIN is self-explanatory
Odo = Odometer, probably matches Tunits (IE C = km, F = mi)
Trip = Trip counter?
The two parameters I really need are power (or voltage and current) and vehicle speed. I could make guesses based on lat/long and SoC, but it wouldn't be very accurate, and I'd need a lot more data points to get an accurate model. Is there an option to select more things to log?
It might be valuable to include him on this conversation
Há algum sítio no LS onde possamos seleccionar as coisas que queremos loggar?
Enviado: 17 set 2018, 18:35
por Apr
ChrgPowr - Pootencia de carregamento
Wpr = Estado do limpa para brisas
RPM = RPM do motor
PwrSw = botao de power do carro: 0- OFF ou ACC 1- ON 2-Ready to drive
PlugState = 0-desligado, 1-ligado, 2-em carga
Gids = GIDs
Tunits = graus C ou graus F
DevBat = nivel da bateria do telemovel
ChrgMode = nao me lembro bem acho que tem a ver se é AC ou DC charge
Seq = nao me lembro também acho que não é relevante e faz parte de mensagns de diagnostico
Trip = Trip index pode variar consoante o LS foi desligado corretamente depois de uma viagem
Enviado: 17 set 2018, 18:37
por plpepapf
migle Escreveu:
17 set 2018, 16:41
Ecrã de definições do LeafSpy:
Enviado: 17 set 2018, 18:45
por Apr
Os dados vão todos de 1 vez em cada mensagem. Podem ser filtrados no servidor.
Mas em vez de estar a enviar assim os dados o LS também gera um ficheiro CSV com ainda mais dados. esses podem ser filtrados antes de ser enviados.
Esta funcionalidade de "server" é mais para gerar paginas em tempo real como dados de viagens.
Enviado: 17 set 2018, 20:27
por migle
Não há problema em enviar mais dados. Mas precisamos da potência, sem isso não dá, potência ou corrente mais tensão. Também a velocidade...
Como é que podemos arranjar isso?
PS: bem, rpm dará a velocidade.
Enviado: 17 set 2018, 22:49
por plpepapf
Hoje ao final da tarde voltou-me a dar erro de ligação.
Request timed out...
Não me estou a aperceber de fazer alguma diferente... será do lado do servidor?
Enviado: 17 set 2018, 23:10
por migle
Deve ser do lado do servidor. A mim também me deixou o Torque crashado (o Torque Pro é uma app de qualidade).
Mas o problema maior que temos agora é que se o log por http só tem esses dados, não serve. Ou vamos pelo CSV, que daria um bocado de trabalho a enviar, ou vamos pelo Torque também, seguindo as indicações que deu o BrunoAlves.
Apr Escreveu:
17 set 2018, 18:45
Aqui a intenção é estar a enviar dados em tempo real para simplificar o processo. Se for necessário fazer upload de ficheiros CSV manualmente, vai ser difícil ter algumas dezenas de pessoas a enviar dados e obter uma amostra estatisticamente relevante.
Alguém me pode arranjar uma amostra dos dados registados no dropbox? No caso do CSV, já encontrei informação e tem, de facto, tudo o que seria necessário (são 157 colunas?!). É curioso estar a fazer log para o servidor de coisas tão idiotas como o estado do limpa-para-brisas e não fazer da corrente e da tensão do pack.
Enviado: 17 set 2018, 23:14
por plpepapf
Será que se consegue que o programador do LS acrescente informação a esse log para o servidor?
Alguém já contactou com ele(s)?
Enviado: 17 set 2018, 23:33
por migle
Isto parece-me intencional, para limitar a utilização do LS Pro para outras aplicações. Quer-me parecer que o LS Pro não quer que se faça nada sem acordo €. Por que razão, escolhendo apenas 17 itens para pôr no log, haveriam de estar entre eles o estado do limpa-pára-brisas, o "modo de carregamento", e o SoC da bateria do telemóvel, e não tensão e corrente??
Isto está tudo no manual do LS Pro, páginas 39 e 40, por oposição ao CSV nas páginas 28 a 31.
Só há duas hipóteses: ou se consegue fazer upload do CSV automaticamente, ou temos de ir para o Torque Pro.
