Tesla lança adaptador Chademo para o Model S
Enviado: 28 nov 2013, 16:32
[IMG]http://cdn.shopify.com/s/files/1/0001/5 ... 1381972705[/IMG]
Caro, mas tendo em conta que por uma simples mudança de parâmetros de software remota para ativar a carga rápida DC levam temporariamente a módica quantia de 2000 dólares...
http://shop.teslamotors.com/collections ... ercharging
Como este cabo tem hardware, comparativamente até parece barato
http://shop.teslamotors.com/collections ... mo-adapter$ 1,000.00
Coming Soon
Take advantage of CHAdeMO’s network of 50 kW charging stations by enabling onboard hardware and purchasing an external adapter. CHAdeMO stations charge at the rate of approximately 150 miles of range per hour of charge with locations primarily in the Pacific Northwest.
This adapter is specifically for North American Model S. A separate adapter is required for European and Asian Model S. For Model S without Supercharging enabled, onboard hardware must be activated to use the CHAdeMO adapter. Every 85 kWh Model S is already Supercharging enabled.
Adapter
For Model S with Supercharging enabled
Available online this winter
$1,000
