Regen *stops* when friction brakes are engaged
ruimegas
Gestor do Forum
Data de fabrico: 09 jun 2011
Mensagem por ruimegas » 07 nov 2011, 23:34
"I was investigating a way to have the SOC meter tell you more directly when the friction brakes were employed. I think I found three signals indicated in the service manual. Target braking force, Regen Braking Force, and Brake Pressure. Here is a graph of a simple test where I pressed the brake pedal three times at the beginning while I was at a standstill, accellerated, then slowly increase brake pressure until I stopped. I repeated again but increased braking more slowly.
What is interesting is when you start to engage friction braking, regen is turned off. They do not simply add friction on top of regen. I guess they couldn't get the feel smooth enough. So it tells us it is VERY important to avoid friction braking because you waste *everything* once you go there - not just an incremental amount above the regen capability."
Em: http://www.mynissanleaf.com/viewtopic.php?f=31&t=6702
Re: Regen *stops* when friction brakes are engaged
Mensagem por mjr » 08 nov 2011, 12:08
Não é essa a experiência que tenho, pelo menos confiando no que o indicador de potência instantânea indica. A mim parece que conforme se vai carregando mais no travão a partir do ponto de regeneração máxima ele inicialmente mantém-se nesse valor e depois vai progressivamente baixando a regeneração.
Voltar para “Engenharia”
