146 kms seguidos sem entrar em turtle ...é mesmo isto que eu preciso.
"Just back from a great 92 mile trip in my Nissan Leaf. All on one charge. Not even down to turtle mode either and not warm at just 10 deg C."
Em: https://www.facebook.com/NissanLEAF.UK
146 kms seguidos sem entrar em turtle :)
- ruimegas
- Gestor do Forum
- ruimegas
- Gestor do Forum
Re: 146 kms seguidos sem entrar em turtle :)
"93.1 miles on a single charge with 3 remaining
Over the last 2 days i have done 93.1 miles , car reports 3 remaining, although web carwings is saying 5.
Pretty damned impressed, i know it was split over 2 days but i didn't bother charging last night as i knew id only be driving locally today.
so..
Tomorrow, being half term and i'm not under pressure if it all goes t*ts up, i'm going to try and get 2 days commute out of a single charge.
On a serious note, it would also be hard to actually run out and come to a stop on the side of the road.
There are enough warnings, audible, the voice reminds you the battery is low, the range indicator starts flashing, the orange PETROL PUMP (lol) symbol lights up, the yellow triangle in the top pod comes on, and finally a banner appears across the top of the map.
The little info display in the lower pod also shows a low battery warning, and you have to dismiss this to get back to the other displays.
A bit further on, the voice reminds you its even flatter and asks if you want to search for a nearby change point.
To sum up, if you get this low a recharge is in order, but its hard to ignore them all...
I might experiment to see exactly i can get till the end, will i get a 2 day commute out of it?
Its half term, so i will try..."
Em: http://www.leaftalk.co.uk/showthread.ph ... -remaining
so..
