Mensagem
por Jafqa » 15 mar 2016, 01:41
Ora bem, eu contactei o fornecedor e obtive a seguinte resposta:
"WallBox have CE certification and IP - waterproof. WallBox is ready for charging 22kW. We assembled down (see the picture) button with LED. And when you want, you can selected 6A-32A or you can always charging 32A"
Informations
Outlet distribution RZJ-D-211 is made from high-quality UV stable plastic. Wallbox drawer is standard equipped with outlets with IP54 protection. In the closet is fitted with DIN rail for 12 modules.
(on order can be equipped with extra protection, different number of sockets, circuit breakers in characteristics C and D and short-circuit breaking capacity 6kA or 10kA
Parameters
Socket- 2x16A Yes
Socket - 32A Yes
Mennekes socket (3x32A-22kW) Yes
Circuit breakers Yes
RCD Yes
Terminals PE-N
Technical
2x zásuvka 230V, 1x zásuvka 400V/16A, 1x zásuvka 400V/32A, 2x 16B/1, 1x
16B/3, 1x 32B/3
Montáž DIN lišta
Stupeň krytí (IP) IP54
Warranty 24 Měsíců
Weight 3,6 kg
